Are there any Unigraphics users out there?
Thanks, Kathy
Here's one.
We use Unigraphics.
Kantha
I've used Unigraphics since v9
Jim Klug
NC Programmer
Janicki Industries
Sedro Woolley, WA
(360)856-5143 ex1808
email: jklug@janicki.com
UG user since V9. Vericut user since V4.4
I’ve been using UG since UGI 20 + years. I have been using Vericut off and on since the early 90’s. John Prun was my first Vericut trainer.
John Joyce
Cadpo
John L. Joyce | Team Leader Ready5 | Cadpo
1490 West 121st Ave, Suite 201 | Westminster, CO 80234
ph 303.252.8485 fx 303.252.8436
em joyce@cadpo.com
wb www.cadpo.com
Get Up To Speed
MCAD/CAM/PLM eLearning, Training & Engineering Services
we have UG, don't use it much though.
Louis
AND HERE'S ONE REASON WHY!
(JUST RECIEVED FROM UNIGRAPHICS!)
01-JUL-2005
LOUIS BIGELOW
TURBINE ENGINES
8839 PIONEER BLVD.
SANTA FE SPRINGS, CA 90670-200
Dear Louis,
Our UNIGRAPHICS_NX development team has investigated PR Number 4473676 and determined
that this problem will not be fixed. If you would like to discuss this further,
please call GTAC at 1-800-955-0000 or 1-714-952-5444 and select the appropriate
support group. If you wish, the representative will connect you with the
appropriate development supervisor, Tim Fu.
The problem where you reported the error, "Thru face does not intersect path
of the tool" to perform subtraction, has been closed as no fix.
Since this problem was reported to us, our engineers have performed a detailed
analysis of the data on at least three separate occasions. Each time we have
been unable to devise a fix and consequently we have concluded that a
resolution to the problem is not feasible.
The problem has therefore been closed as No Fix in our database, and no
further attempts to resolve it will be made.
The data for this issue will remain in our test suite and should it be
discovered fixed in the future, you will be informed of this.
Sincerely,
The Global Technical Access Center Team
We use Unigraphics since UGII 3.1 and VERICUT since V4.1
I started to use UG with V10.3
I use a combination of UG and NCL for manufacturing. They complement each other nicely. UG's strengths are NCL weaknesses and vice versa. This system has worked necely for the last 5 or 6 years. I am able to easily integrate the code with the ability to quickly add any required modifications of updates.
John Gates
Hi!
I use UG since 1990 .
/sae
:x
I have been using pro/E
and now i want to learn how to use UG now~
so i may be one user~
We have used UG since v13, now at NX3
Vericut user since 4.4
Chris Martin
Cam Programmer
Red Bull Racing
Chris M
UK
I'm using UG since V15, Vericut since V4.4
Thomas Schnider
CAM Programmer
Pilatus Aircraft Ltd.
________________
Thomas Schnider
CAD/CAM Engineer
I've used UG since v6 (1988) and Vericut since v1.2 (1989) but have been out of the loop for some time working on manufacturing standard work.
It's refreshing to recognize so many names and companies in this forum.
Rick Vernon
Pratt & Whitney
860-565-3293
Richard.Vernon@pw.utc.com
