#1 2015-01-05 18:13:14
bpatel
C-Axis motion
I have error message "The direction to move is undefined (180 degree move set to Shortest Distance)." for C-axis motion, this is Integrex-200III machine with Mazatrol640t-control.
N376G83X39.999C0.Z-3.147R0.F55.M210
N377C180. - error here
Does anybody has idea how to fix it?
#2 2015-01-06 00:11:03
Moderator
Re: C-Axis motion
Go to Control Settings, Rotary Tab and change the Absolute Rotary Direction to Shortest Distance 3
#3 2015-01-06 16:41:37
bpatel
Re: C-Axis motion
Thank you TONY,
I am using V7.3, I changed it to "Shortest Distance 2" and it works. Is there any difference between Shortest Distance 2 vs 3?
Bhavin
#4 2015-01-06 16:46:46
Moderator
Re: C-Axis motion
If you were using Shortest Distance originally you should use Shortest Distance 3 now.  Using Shortest Distance 2 will make the C axis go in the opposite direction to Shortest Distance when doing a 180 degree move.
Shortest Distance 3 is the same as Shortest Distance except that it does not output a warning message when doing a 180 degree move.
#5 2015-01-06 18:13:04
bpatel
Re: C-Axis motion
But in version 7.3 doesn't have Shortest distance 3 - option. How can we add in control setting.
#6 2015-01-06 18:16:35
Moderator
Re: C-Axis motion
Sorry, you will need to update, Vericut V7.3.3 is the current version
#7 2015-01-06 18:18:27
bpatel
Re: C-Axis motion
Ok,
Thanks.
