I have error message "The direction to move is undefined (180 degree move set to Shortest Distance)." for C-axis motion, this is Integrex-200III machine with Mazatrol640t-control.
N376G83X39.999C0.Z-3.147R0.F55.M210
N377C180. - error here
Does anybody has idea how to fix it?
Go to Control Settings, Rotary Tab and change the Absolute Rotary Direction to Shortest Distance 3
Thank you TONY,
I am using V7.3, I changed it to "Shortest Distance 2" and it works. Is there any difference between Shortest Distance 2 vs 3?
Bhavin
If you were using Shortest Distance originally you should use Shortest Distance 3 now. Using Shortest Distance 2 will make the C axis go in the opposite direction to Shortest Distance when doing a 180 degree move.
Shortest Distance 3 is the same as Shortest Distance except that it does not output a warning message when doing a 180 degree move.
But in version 7.3 doesn't have Shortest distance 3 - option. How can we add in control setting.
Sorry, you will need to update, Vericut V7.3.3 is the current version
Ok,
Thanks.
