Good morning
Siemens 840D the vericut I can't read the following interpolation "I and J" cyclic G02 G03, what are the parameters to be set and in which file ??
Signaling: Incorrect circular interpolation. r1 = 0.999914, r2 = 0.999831
block example:G02 X56.574 Y-236.346 I = AC (56.32547) J = AC (-235.37755)
thank you
Go to Control Settings > General > increase the Calculation Tolerance slightly
Thanks Tony
Now it works you were very kind, I set 0.0254mm as the value.
0.0254 is fine.
