When using a tool with an insert and the cutting profile of that insert is perpendicular to the cutting motion, Vericut should not give the error: Collision between Cutter of the tool "xxx" loaded in component "Tool" and Cut Stock of "Stock" with Spindle off at line...
This would make it possible to simulate and verify "scraping" and "interpolation turning" operations
You just need to add BroachModeOnOff for that instance, its also required for broaching and interpolated turning.
Great,
I had tried this macro, but it didn't work. Just noticed that I had a typo in the command ![]()
See samples\cycle806 ...vcproject in 95x for an interpolated turning example
Very nice sample. ![]()
