#1 2023-06-18 11:24:51
WCooper
Speed of Simulation Play Slower Settings
Hi-
A 100 percent accurate to real life tool movement speed, including toolchange movement speed would be nice. The current slowest settings are still fairly fast and single block only conveys a certain amount of detail.
#2 2023-06-20 08:48:21
Moderator
Re: Speed of Simulation Play Slower Settings
If your simulation is too fast change the Min Motion Dist to 0.01 and the Max Motion Dist to 0.1, now when you move the slider off 100% it should be slower.
If you want to go even slower, make these values smaller.
Tip, if you want to see something in a single block, repeatedly tap the + key or keep it held down.
#3 2023-12-14 14:21:11
AClements
Hi Tony
what's the largest Max Motion Dist I can use? currently at 10 but it runs very slow looking to speed things up if i can.
TIA
#4 2024-01-11 16:10:49
Moderator
I dont think there is a limit, but results will vary depending on what you are doing.
