#1 2013-07-29 19:04:19
vortxx
Continue processing G code before previous motion completes.
Hello,
I am using a rotary indexer which is programmed through an external control box and indexed with an M code. It is set so that it doesn't wait for a finish signal; after the machine sends the M code (to index) the program will continue processing immediately afterword. I have everything setup correctly in Vericut except that Vericut will wait for the rotary motion to complete before moving along in the program. I would like to mimic the actual machine behavior as closely as possible so is there a way to tell Vericut to continue processing the subsequent lines of NC code before the current motion is complete?
#2 2013-09-12 15:31:45
MustaphaC
Re: Continue processing G code before previous motion completes.
This might be possible to do but you will need to use a second sub-system and sync the motions. Not sure if it is worth it?
