Hello,
I am using a rotary indexer which is programmed through an external control box and indexed with an M code. It is set so that it doesn't wait for a finish signal; after the machine sends the M code (to index) the program will continue processing immediately afterword. I have everything setup correctly in Vericut except that Vericut will wait for the rotary motion to complete before moving along in the program. I would like to mimic the actual machine behavior as closely as possible so is there a way to tell Vericut to continue processing the subsequent lines of NC code before the current motion is complete?
This might be possible to do but you will need to use a second sub-system and sync the motions. Not sure if it is worth it?
