Hello everyone
I just came out of retirement and have a lot of catching up to do. My new employer has purchased 1 copy of vericut (with UG interface). They have a huge Unigraphics tool library that I would like to transfer into Vericut. Can this be done? Can just sections of the library be transfered?
Thanks Rich
Rich,
As far as i know this cannot be done in a simple way. Perhaps with some fancy VB or TCL programming.
At our company we use WinTool toolmanagement software. With this you can generate the UG & Vericut toollibraries when you add a tool to the database. We use this software to prevent recreating tools over and over.
Good luck,
Patrick Delisse,
DutchAero
I'm very curious about how you use WinTool. I have plans to build a big tool library from where the users can use "Reference".
Can you explain a bit further how you use it?
Svante
Svante Eriksson
System owner
WinTool is based on an access database, in wich components (cutting tools, holders, insert, ...) are defined by specifying the component parameters. A drawing of the component can be automatically generated or imported into WinTool.
The components can be assembled to get a machine specific tool assembly. With this assembly you can store different cutting conditions for multiple materials.
The tool assemblies can be grouped on a part specific toollist.
WinTool can generate from the tool assembly a vericut library and a UG model by rotating the profile of the cutting part and the holder part.
When you want to use a user defined vericut/UG model, you can store the path to that model with the tool assembly.
From the toollist WinTool can export a presetting file witch can be imported on a Zoller or Kelch presetting device.
WinTool can also manage the stock, purchase and usage of components.
We choose for WinTool because as a midrange company like us cannot affort to buy a "Heavy" system like TDM, and WinTool provides all the functionallity we were looking fore.
For more information see: http://www.datos.ch/index-e.htm
DutchAero
