:? I?m use the H-code for a tool change for the fact that my post does not output M6 so I?m using the H-Code as a toolchange Example.
( N111G43Z13.1725H01M08 ) my problem is that when it reads this line the tool change is made but it execute Z move into the part then retracts to the proper z position in this case Z13.1725 this only happens when I add TOOLCHANGE and TOOLCODE to the H register, how can I get Z to start at the right Z, one other thing is this only happens at the beginning of the program only :?
here is one way to do it
Have you post output a consistent message for the operators:
(MSG, TOOL# 1) 1) being the tool number
Add a word :
LOAD_TOOL
Do a substitution
(MSG, TOOL# / M06 LOAD_TOOL
this may require tweaking depending on specific output
Add a register
LOAD_TOOL
Put your TOOLCHANGE and TOOLCODE there
thats most of it
have fun
thanks Dave, that worked out good. by the way if you know Marty Accosano tell that Character I hey..
thanks again.
