#1 2006-02-17 17:27:13
EngMfg1
H-CODE FOR TOOL CHANGE
:? I?m use the H-code for a tool change for the fact that my post does not output M6 so I?m using the H-Code as a toolchange Example.
( N111G43Z13.1725H01M08 ) my problem is that when it reads this line the tool change is made but it execute Z move into the part then retracts to the proper z position in this case Z13.1725 this only happens when I add TOOLCHANGE and TOOLCODE to the H register, how can I get Z to start at the right Z, one other thing is this only happens at the beginning of the program only  :?
#2 2006-02-17 22:07:39
DaveF
Re: H-CODE FOR TOOL CHANGE
here is one way to do it
Have you post output a consistent message for the operators:
(MSG, TOOL#  1)         1) being the tool number
Add a word :
LOAD_TOOL
Do a substitution
  (MSG, TOOL#         /        M06 LOAD_TOOL
this may require tweaking depending on specific output
Add  a register
LOAD_TOOL
Put your TOOLCHANGE and TOOLCODE there
thats most of it
have fun
tongue
#3 2006-03-06 21:48:54
EngMfg1
thanks Dave, that worked out good. by the way if you know Marty Accosano tell that Character I hey..
thanks again.
