Hello,
:?: Is it possible to change the default folder in the "Open Project" dialog?
It currently defaults to "C:\Users\Jim" folder. I would like to change the path to the folder where I keep my .VcProject template files.
TIA
Jim
v6.2.1
Auto-Diff, OptiPath
No Machine Simulation
__________________________________________
Dell XPS 410, Intel Core2 @ 2.13GHz
4GB memory, NVIDIA GeForce 8600 GT video card
Vista Home Premium
right-click on the VERICUT icon on your desktop
Properties
Start in = C:\Users\Jim ----> change it to the folder you want
The specified folder will always be Working Directory for the session.
You can even create a new icons for multiple work locations.
OUTSTANDING!!!......Thanks a lot Serge.
While we're on the subject, there's a couple of questions I have.
1. In the same dialog, there is the Shortcut pop-up menu.
Can these menu items be changed or even omitted?
I don't have any need for the Samples, Showroom and Training folders. I would like to replace them with folders I use on a daily basis.
2. I have my preferences set to "Choose project file on startup".
If I startup Vericut and the Open Project dialog appears, shouldn't Vericut close if I decide not to continue and press the Cancel button?
Instead Vericut loads up the default .VcProject and I have to wait until it is open before quitting. Doesn't make sense to me.
Anyway,
Thanks again for your help.
v6.2.1
Auto-Diff, OptiPath
Vista Home Premium
To have another directory listed along with Library, Samples, Showroom, and Training add this to your cgtenv.bat file:
set CGTECH_MyStuff=D:\MyPath\
where MyStuff is whatever name you want
and D:\MyPath\ is the desired fully qualified directory name.
We've used this for years to get to our master files.
Add several of these if you need more than one.
Jerry
Jerry Millett
Hey Jerry,
Thanks for your reply, but I seem to be having some problems making this work.
I'm able to add in the path as you stated, but when I try to save it, I get this message:
Cannot create the C:\Program Files\CGTech\windows\commands\cgtenv.bat file.
Make sure that the path and file name are correct.
I've tried this several times and tried different folders.
What am I doing wrong?
TIA
Jim
v6.2.1
Auto-Diff, OptiPath
Vista Home Premium
the file is write protected
RT click properties
general tab
uncheck read-only
OK...got it to work...nice...it's the little things that make me happy. ![]()
Dave,
You were close, but you helped a blind squirrel find a nut.
The properties write protect was already unchecked, so I tried the Security tab and changed the user permissions to allow full control and it worked.
Thanks Dave and Jerry for your help.
Jim
v6.2.1
Auto-Diff, OptiPath
Vista Home Premium
