Hello support team.
For some reason, I did the "CNC control upgrade" from Vericut 5.4 to 6.1.1 and this new one didn´t obey the "shortest option" for rotary "C" axis travel endless. Could you please help me in this issue
Thank you and best Regards from Brazil,
Daniel Krabbe
Embraer
São José dos Campos, Brazil
On the rotary tab under Configuration\Control Settings..
Absolute Rotary Direction
Shortest Distance option
You can set always CW/CCW, etc.
Hope that helps.
I'm having the same issue with this endless 'c' not behaving.
I have the Absolute Rotary Direction Shortest Distance option set
and I still have a total 'c' axis rewind when 'c' exceeds 360°.
This is not how the machine (Hermle c800u - heid426)reacts.
Is there something I'm missing here or elsewhere? :?
Any help would be much appreciated
Cheers Jon
Cheers Jon
You have to change the Axis Rotary Type to "EIA (360 Absolute)" for the specific rotation axis (in your case it is the C-axis Rotary Type)
Hi Martin,
Still no good - 'c' is still rotating back to 0° when hitting the 360° limit :? :?
Thanks all the same
Best Regards Jon
Cheers Jon
I've just set the C-axis Rotary Type to "EIA (360 Absolute)" and the Absolute Rotary Direction to "Shortest Distance" and it works perfectly for my Hermle C40U C-axis
I must be missing something else.
I think maybe a call to support is required here.
Thanks once again.
Regards Jon
Cheers Jon
Hi again,
Had another fiddle before going to support.
I found that if the " Output Intermediate Points" is set to "No"
the 'C' doesn't physically rewind .
What will this do for other rotary 'C' moves?
Cheers Jon
