Hey everybody,
Not a new Vericut user but new to the forum - Can anyone tell me if its possible to use two models & have them automatically transfer to a second setup with new independent orientations?
I'm currently running Vericut 6.1 with the Verification, Multi-Axis & Auto-Diff options...
I'm familiar with how to set the transfer up with one stock model, but this one is really stumping me - with both models attached to a common stock component they become "glued" together (after cutting the first position) in their current orientation to each other (I have two parts aligned vertically - like a column). When the cut stock is transfered to the second setup I need to rearrange the orientation of the stock models separately (each piece turned 90 deg. & then aligned vertically in a column again)
I fiddled with trying two stock components, but Vericut hides one as soon as I start running the code... Is what I'm trying to do even a reality with base Vericut?
Thanks for any input.
Welcome to the forum,
Because the workpiece view is static, you can only have one stock component displayed. To see 2 stock components, you need 2 views.
In the second view, right-click, Attach Component > select second stock name from the list. Each stock has its own view.
To locate the stock relative from one another, I would recommend using the Machine/Cut Stock view. Even though you will not see the machine move, you will see both parts at once.
Serge,
Thanks for the advice - I appreciate it. I'll give it a try when I get in tomorrow.
UPDATE:
Great Success! (Hi Five) that was what I need to know. Thanks again.
I have same problem here, I need to machine a pair part ( 2 blocks of stock separately), and next setup I want move each block to different position to machine the other side.
When I hit play button Vericut merge 2 blocks of stock become 1 cut stock, I want them separately. So I can position for next setup
Any way can I do this ?
[/img]
Qmp
Qmp,
I had the same result at first too - from your screen shot I see that you have both stock models attached to the same stock component. Instead, create a second stock component & attach one stock model to each.
Then, in your second setup, create two stock components with the exact same names. Each model will transfer to its respective component.
Take a look above & follow Serge's advice on how you can see each of the models being cut when you run your simulation
Good luck, I hope this helps
[img][/img]
I got it, but they are in two separated windows, like Mr SergeV metion above.
I would like to see them together in same window workpiece view
[img][/img]
Qmp
I have the same result, It looks like one at a time is all you can do in workpeice view (as Serge indicated above).
I don't know about your setup, but I only have the basic vericut package- I'm guessing you need to have full-blown machine sim. to be able to see both parts cut together (so you can simulate in machine view).
See the reply of Serge:
There is no way in the workpiece view, but the Machine/Cut Stock view.
You will have to open an enhancement request with CGTech for this.
SergeV,
Can you please log this an enhancement request with CGTech.
Thanks all
Did you try saving a VCT of each?
Than load the 2 VCT files in one stock
Yes, I did, but I would like to see mult. cut stock in work piece view
P-cnc
An Enhancement Request has been entered on your behalf.
Thanks a lot SergeV.
Have nice weeken.
P-cnc
