I sectioned the part, and tried measuring from the axis of the hole to an edge, or vertex, but I am not actually getting the edge, and therefore not an accurate measurement.
Austin NC APT administrator.
and other ANC applications.
Here is a trick I have found:
I use Feature/History and pick on the face next to the countersink and write down the Z value. I then select the hole and write down the X and Y values of the hole. This gives me the position of a point in the center on the top face.
I then type these values in the Air Distance XYZ and define a vector IJK in the X direction (1, 0, 0)
Multiply the air distance by 2 and you have the diameter
Instead of writing down the Z value, use Cntrl C + Cntrl V to copy & paste from the X-Caliper menu.
If many countersinks are to be measured, try creating a Coordinate System with a suitable name (e.g. XCal_csink) using the Orient, Circle option and digitize the first countersinked hole.
Then make "XCal-csink" active via
Right Hand mouse Activate Coordinate System > XCal_csink.
Now X-Caliper, Air Distance needs only "X0Y0Z0I1J0K0"
To measure subsequent countersinks, change the Coord System "XCal_csink" to the required hole centre, and, with X-Caliper Air Distance still open, press Apply.
I put in an enhancement request for countersink measurement
in X-caliper back in 2000. Is there enough interest in the user
community to request this as an enhancement to in a future
Vericut release?
JoelV
Serge and Mike,
Thanks for the tips, but my csink is not going to be this easy to measure. It is not done with the Z-axis. It is inside a wheel, and done with a 90 degree angle head. I'll have to check, but I'm not sure if any of them are aligned with the X-axis, either, but if so, I can probably use an adaptation of this method.
Joel,
I for one would like to see this enhancement. I don't see why the "edge" or "vertex" can't pick the edge of the csink, and then you could measure to the axis of the hole, but I haven't had any success this way.
Al,
1. In this case, Mike's method will work better. by creating a Coordinate System at the top of the csink with its Z axis pointing along the hole axis, X will be normal to the hole wall.
2. for "edge" we look for 2 planar surfaces to calculate a straight edge
OK,
I did get this to work, but it's a long road to get there.
Please add csink measure to X-Caliper.
An Enhancement Request was entered on the behalf of the forum.
Hi.
How is the idea. if we save the cut stock in igs and inport into cad( auto or solid works) , then measuring the counter sink . will it work. i don't have licence for exporting model , so i couldn't try.
cheers
Hi ,
I just tired creating igs in solid works and importing it into solidworks again. it works
You are able to measure all the features u want to. i wish i have export licence .
can some one try it in the vericut and put a post for the vericutter's
cheers
