On Youtube I have seen Vericut running with the nc code in the simulation background instead in of its own window. How can I enable this?
steve austin
Steve, take a look in the Vericut Help > Automating Vericut > Batch Processing.
Vericut will run with no GUI and generally process a vcproject faster than if the GUI was open, using batchp command will open the vcproject when its finished so you can review the result.
Sorry, I did not explain myself correctly. What I am after is seeing the gcode in the workpeice veiw and machine view. Instead of seeing the nc code in its own window. Does this make sense?
All you need to do is enable HUD (Heads Up Display)
Info > HUD Control > Enable and select what you want to see and where you want to see it.
