#1 2017-07-21 12:56:10
astro8893
cycle time
Where can I find the cycle time in Vericut 7.3
#2 2017-07-23 16:07:02
MustaphaC
Re: cycle time
I see at least 3 ways to get the cycle time, in Info > Status you can use the Configure button and add "Time" to follow the cycle time during the simulation.
Info > VERICUT Log... can be opened at the end of the simulation and you see an overview of total cycle time and time for each tool, for example:
Seq.  Record             Tool Description                                      Cutter Height  Cutter Stick Out  Time        Air Time
   1    12: N14T8M6H0    8: 1.00 X .122CR X 2.0 F.L. (3 FLUTE) HSS END MILL    4              2.25              0:12:24     100%
   2   397: N397T9M6H0   9: .500 X .250CR X 1.50 F.L. (2 FLUTE) HSS END MILL   3.5            2.05              0:04:50     100%
   3   506: N504T10M6H0  10: .500 X .250CR X 1.50 F.L. (2 FLUTE) HSS END MILL  4              1.5               0:04:05     100%
   4   618: N614T12M6H0  12: #30 NUCON DRILL                                   4              1.7               0:01:37     100%
   5   650: N644T13M6H0  13: .375 X .000CR X .750 F.L. (2 FLUTE) HSS END MILL  4              2.25              0:02:01     100%
      Total Time:        0:24:57     100%
Number of Errors: 43
Number of Warnings: 0
Total cycle time since last rewind: 0:31:52
Total air time since last rewind: 0:25:50
Finally at the end of the simulation you can use File > Create Report > (Text, Html or PDF) to generate a report of the simulation, you can find several Report templates in VERICUT library folder...
