I have a Vericut user file I last modified in Sept 2005. At that time, everything in the file ran fine (that I can recall). In addition, I have 4 other user files with similar hardware setup the same exact way.
This afternoon I need to check something in my one file. The stock disappears with the message ?Cut Stock was unclamped and is temporarily saved in Unclamped Stock?. I compared all five component trees, before and after and can?t figure out what setting changed.
By the way, the four other files run just fine.
I have never had to deal with ?unclamped stock? before. ~Kathy
Is Model, Delete Material, Update While Simulating checked ?
If it is uncheck and run again.
Gavin -
Thank you! That was the problem. And now I can get 'Delete, Material' to work.
I'm a happy camper...
~Kathy
