#1 2004-11-11 15:47:18
Creg
Working Directory
I think I've requested this already but it would be really nice if the working directory was saved with the user file so that when you call up a file you don't have to select the working directory each time.
Creg
#2 2004-11-11 19:33:13
Al_V
Re: Working Directory
That sounds like a good idea.
Also-
How do you change your working directory and make it stick?
I have clicked   File>Working directory>choose a new dir,  but next time I enter VC, I am back to my old working directory.
Austin NC APT administrator.
and other ANC applications.
#3 2004-11-11 20:03:29
GavinP
Also-
The initial working directory can be changed by editing the start in box in the properties of the Vericut icon.
#4 2004-11-11 21:26:13
Louis Bigelow
I've asked for this every user group meeting for the last three years..
the process that vericut appears to use is: (watch every demo they do.
they all demo it the same way!)
open vericut.
change working dir
load user file.
run process.
--four steps--
the way I want to do it is...
double click user file.
run process.
-- two steps --
time is money!
if you didn't set the working dir. your files may not be in the right place.
I try to make it a point to use full path & extensions so it dosn't happen
often, still happens sometimes though.
and storing them in the startup batch file as parameters is also
inadaquet. We have >30 customers with several hundred active part
numbers. "custname\partnumber\mill.5ax"
Louis
#5 2004-11-12 02:48:49
Al_V
Thanks!
#6 2004-11-15 22:41:12
Louis,
If you set your Folder Option in the MS Explore window to start VERICUT with a USR extension, you can start VERICUT by double-clicking on the file. The working directory is then automatically defined as the folder where the USR file resides
#7 2004-11-16 15:00:19
Louis Bigelow
Serge:
Thanks, that works. I do remember this not working in prev versions.
(picking up the working dir) Or am I getting Senile?
Louis
#8 2004-11-16 16:15:57
Louis,
What happens is that when you install a new version, you need to change the path for the application otherwise it will not work.
As for your other question, I am not qualified to answer  :wink:
