#1 2005-09-27 21:47:30
m74uk
Cut Stock
The ability to 'shake off' excess stock.
Sometimes when I profile, I will create a radius from within a square piece of material. As such after I have finished simulation. I'm left with the excess in the corners. Thats fine until I want to take the cut stock to the next op. I'm stuck with these corners which show tool rapid collisions on Vericut, yet I know the material is not there.
It can also happen with Turning when we part off. We are left with excess materail in mid air. As such we usually define a tool tip 6 feet wide just to cut off the excess.
A button when your finished simulation to shake off the excess would be nice.
M74UK
#2 2005-09-28 13:31:20
Kantha
Re: Cut Stock
Will the delete material under the model menu do want you need?
Kantha
#3 2005-09-28 17:34:41
m74uk
Re: Cut Stock
Yes..............a bit like that.
Thanks :oops:
