#1 2015-07-09 17:20:08
Mitch_vc
VERICUT Reviewer - NC Program (NC Program Listing Area)
We started using VERICUT Reviewer, and everything works for about week, and now I can't open NC Program (NC Program Listing Area).
Everything else works.
VERICUT Reviewer 7.3.1 on one computer and VERICUT Reviewer 7.3.3 on second computer.
VERICUT 7.3.1 (64)
Windows 7 (64)
#2 2015-07-10 10:53:46
Vericut_McAtee
Re: VERICUT Reviewer - NC Program (NC Program Listing Area)
The Reviewer is version dependent. So if a job was saved with version 1 it must be played with version 1. It is not compatible with a later version or a newer version.
#3 2015-07-13 23:36:49
Mitch_vc
I have same version 7.3.1(64) VERICUT and 7.3.1(64) VERICUT Reviewer on my computer, still can't open NC Program Listing Area.
#4 2015-07-30 18:19:34
rdix33
If the Program moved or was renamed from the original area it was located it will not open.
#5 2015-09-09 14:58:08
Mitch_vc
Program was not moved, and wasn't renamed.
I think this disappearance, has something to do with preferences - PDF/HTML/EDITOR,
because I played with preferences. After that I was able to open NC Program Listing.
But, I'm not sure about that.
Anyway, Thank You VERICUT Reviewer is working now, and we are using.
Mitch
#6 2015-10-01 23:36:38
Mitch_vc
Problems with VericutReviewer 7.3.3
1. Take long time to save VC reviewer file.
2. When I check, Check Box "Replace Material When Stepping Back" in File - Properties, and reopen VERICUT  the Check Box is uncheck.
Mitch
