I want to set the default size to 640 x 480 and the default location to be in the center of our screens which is approx 500 and 300 respectfully.
What file do I need to change?
Mark
I don't bother with Vericut's .avi creator, I use Camtasia. Very user friendly & cheap
Mark,
the setting for size and location are in the .usr file
IMAGE_RECORD_START_XÂ Â Â Â Â Â IMRSTRTX 0
IMAGE_RECORD_START_YÂ Â Â Â Â Â IMRSTRTY 0
IMAGE_RECORD_WIDTHÂ Â Â Â Â Â Â Â Â IMRWIDTH 1029
IMAGE_RECORD_HEIGHTÂ Â Â Â Â Â Â Â IMRHEIGT 714
.....Tom
Chaddy, thanks for the tip. Can you give me more information on Camtasia and how you use it within Vericut.
TomB, thanks I'll make the changes to my usr file.
Regards
Mark
TomB,
My Usr file has those values in it, but when I select:
File, Images, Record, it throws the default values in there and not the values that I can see in my user file.
Am I doing something wrong or is this a bug?
Mark
you could get the cheaper 'snagit' if you wanted but this is the best screen capture software I've seen
http://www.techsmith.com/products/studio/default.asp
I know I'm advertising a different product and this is probably a 'faux pas' but if you set camtasia up properly (which is stupidly easy to do) it's an absolute breeze to record your screen just by pressing 'F9'
Defaults for base window screen size and location are in cgtech_54_xxxxx.prefs found under c:\documents and settings\loginname . This is were window size, screen location, view mode, Csys display etc are stored.
The primary problem we have with AVI recording is speed. Does CAMTASIA or any of the others record the frames when OPENGL is active?
Val,
External recording applications like CAMTASIA or HYPERCAM will record frames in OpenGL.
I checked out some of the screen capture software. They work, but you need to be aware of the limits.
They record the OPENGL display, but there can be "syncrhonization" problems. They record real time. Fast tools like drills become a blur. Tools/moves that take longer to compute playback the same way, slow. As the setting for FPS go up, so does CPU use, then Vericut and the capture software fight each other and everything slows down. The AVI file grows even larger and playback slower.
This is the main thing we like about the Vericut image recording, the playback FPS and display syncronization are handled well.
