#1 2014-09-24 21:12:00
mcam
Macro SpindleOrient
Where is the setting for the orientated spindle angle/position?
I have a fine boring bar, that when toolchanged in, is orientated incorrectly even though it is modelled correctly (with the boring tip at 6 o'clock looking down on the spindle)
When I MDI the M19 (Spindle Orientation Command), it orientates the tip to approx. 4 o'clock looking down from the spindle.
New Zealand Vericut Reseller
#2 2014-09-26 10:35:38
Re: Macro SpindleOrient
A few ways of doing this.
The easiest would be to orient your Spindle Component around Z by 60 degrees.  So each time you use M19 it orientates to the 4 o'clock position. ( dont forget to save your mch if you do this )
Another way is to add the SpindleOrient macro to M19 with an Override Value of 60, this will give the same result. ( dont forget to save your ctl if you do this )
If you need further help, just contact your local CGTech Technical Support Engineer
#3 2014-09-29 02:35:19
mcam
Thanks Tony. That worked a treat (I used to the second method)
