Dear all,
Here is the cycle command in the program.
CYCLE85(180,175,1,,123.6,0.5,291,291)
How can I interpret all the parameters? The explaination of Word/Address
can be refered in the attached picture. Thanks.
David
Caterpillar Inc.
Here you can find the manuals of Siemens 840D with an explanation
of the parammeters.
http://www.automation.siemens.com/doconweb/
Succes, Dolf
I guess you would've already figured out the working of cycles inside Vericut by now.
If not, did you try adjusting the settings through Setup>Control>Settings>Cycles?
There is also some documentation regarding the interpretation of cycles inside vericut. (Control Settings, Cycle tab).
Prasad Rayasam
Ingersoll Machine Tools
