#1 2013-12-27 12:26:48
girishnilange
Circular motion blocks with I,J,K or R values in Modal
Hi.
I am dealing with a particular NC program which has the I, J, K and R values (for circular motion) defined in a modal fashion. They are not posted repeatedly unless their values change (when interpolating a cirlce with a different radius).
I have managed to adjust the controller to simulate this in Vericut by setting up variables to store the I/J/K/R values and reuse them in blocks with circular motion without I/J/K/R codes in them.
I wanted to know is there is a easier setting available in Vericut for this?
Whether such blocks run on the actual machine is a different issue, with this question I am expecting to know how flexible Vericut can be in changing the controller.
Thanks in advance!
Best Regards
Girish
#2 2014-03-27 08:54:17
Re: Circular motion blocks with I,J,K or R values in Modal
The solution you have using the variables is correct, there is currently no easier setting available in Vericut
