Every time I run a tap simulation I get tapping collision alarms for the minor ID of the tap. Usually the collision amount is .0001" or less. I have reviewed the tool info and cannot find anything wrong. Am I doing something wrong?
In File > Properties, check option "Model Export Cut Mode" and try again
Thank you for the reply. That did not correct the problem. But, while I was in the properties tab I found "Minimum error volume". I set that to .001 and it corrected the problem. Thanks for pointing me to the right direction.
