If there are licensing messages or errors upon reopening VeriCut 7.1.1 x64 in a Win 7 x64 environment, the "Environment Variable" may not be correctly set by the default installation. This was corrected through CG Tech support for me and I will pass this along. In Win 7, go to Control Panel--> System--> Advanced System Settings-->click on the "Environment Variables" button at the bottom of the "System Properties" pane--> In the "System Variable" pane at the bottom of the page, the LSERVOPTS string must be edited to show this string -s "C:\Program Files\cgtech\7.1.1\windows64\license\cgtech.lf" . This was a standard installation with the default directories used...
After this was corrected the 7.1.1 will now open and close properly after all situations and restarts/reboots. My thanks to Tim Mcdonald for this fix.......
My problem is this installed the latest version VERICUT 7.3.3 and click to open it it gives error and a message : License Server found, but license information CGTech are not present ( may be wrong version ) .
Because I think that is my license that needs to be edited , do not know ...
... Can anyone help me ?
What version is shown in the license administration panel on the license server?
If it is not 7.3, then you need to get the correct license version from CGTech.
I went to "Start> All Programs> CGTech VERICUT 7.3.3 > License Administrator > License Administrator SentinelLM ( WlmAdmin ) , Subnet Servers and clicked the signal d + and then the + sign again and then appeared to version 7.3. this procedure is right?
If so, what should I do if the version is correct?
Thank you for your attention and help.
Have you updated the license server to version 7.3 too?
Is your license server a virtual one, then you need a different license file.
I uninstalled and reinstalled , tried all versions , which were 7.0, 7.1.4 , 7.3 , 7.3.1 and 7.3.3 , all have the same problem the same error message.
I changed the license files with each other and nothing , the problem perciste .
I'm impreção that are license files that need to be edited.
Thanks for your help and attention.
You can't edit the license file, you will have to request a new license file if you change the server or its hardware.
But my Vericut is not the original , it was through a download, and the Crack file came along with it , I did not buy the software .
Where could I find a valid license aquivo ?
Thank you for helping me and for having patience with me .
That success becomes routine in your life .
Dude, you have "cojones"...
Just go away.
Michael Stevenson
Vericut Programmer
PCC Aerostructures
