Good Day Gents,
I,m having a rather strange occurance when I start up VC7.0.3.
All the Toolbar Icons are prefixing with 'menu...' , the explorer tree with 'pro...'
It's almost as if I'm seeing the debug widgets.
Tried reloading the software but no go
Any Ideas what is going on?
W7 64bit
Cheers Jon
Hi Jon,
Make sure the correct language is selected in vericut.bat:
if "%CGTECH_LOCALE%" == "" set CGTECH_LOCALE=english
Then see for the corresponding language that the VcRes.local file exists, for "english" it should be in the folder:
C:\cgtech703\classes\english\
Thanks for the reply Mustapha,
Everything is as so in the vericut.bat file etc.
Vericut opens fine from a fresh start i.e after a reboot,
yet returns the additional 'rogue' text on start up after the first closing of vericut??
Cheers Jon
That is strange. Exit VERICUT, Reset your preferences (Start > All Programs > CGTech VERICUT 7.0.3 > Utilities > Reset Preferences)*, start VERICUT, it will start as if you just installed it.
Then close and reopen VERICUT to see if it still return the "native" menu names...
*Note that you will loose all your previous settings, like window sizing, icons arrangements etc..., you will have to redo those settings...
Finally, got this sorted.
It seems that an anti-virus upgrade was for whatever reason
playing games with vericut,re-installed the a-v and everything is now fine,
Thanks for your help, very much appreciated.
Cheers Jon
Thanks for the information...
