#1 2005-11-10 08:56:55
umesh
Machine co-ordinate setting
     I have got a 3-axis component. I have verified the same in vericut(using g and m-codes). I have added a 3-axis vertical Milling machine.
I need to match the co-ordinate system of the component and machine.
whats that i have to do.
Because by default the component is getting placed else were and program runs elsewere.
Thanks and Regards
Umesh B N
TCS
Bangalore, India
#2 2005-11-10 14:27:08
Anonymous
Guest
Re: Machine co-ordinate setting
umesh
Did you try going to the component tree and reposition your component.
You could go and create a new or alter the one your using and then move your component .
hope this helps
Joey
#3 2005-11-10 16:26:51
Hello Umesh,
You have a part in VERICUT, you have the machine and you want to locate your NC Program origin.
Setup > G-Codes> Settings; Tables tab
Add/Modify
Table Name = Program Zero
Select From/To Locations
To: Component: Name = Stock
Pick the Arrow next to the Stock entry
Select the NC program zero on the stock
