#1 2023-12-15 17:41:10
WCooper
file compare: G-Code Before and After
In 2 scenarios it would be nice to load to G-Code files side by side and see the differences:
Before and after Vericut (I make edits in the Vericut process, then try to go back to CAM based on those edits).
Also, Before and After the making the part. It would be good to pull a program from the machine and compare it to the original to see what changes were needed at the machine.
#2 2024-01-03 08:04:36
Re: file compare: G-Code Before and After
Use the worlds best -free- text editor to do this: Notepad++
It has a strong compare plug-in that works fine.
You can also use syntax-formatting, which makes it easier to read the NC-code.
https://notepad-plus-plus.org/
