Probably an easy fix, however, I cannot figure it out, machine configured with 4th axis rotary, during verification, it seems the entire machine is rotating around the part versus the part rotating with the 4th axis, is there a fix for this? thank you
Right click in a View > View Attach Component > make sure Base is selected.
wow that was simple, thank you
do you know why I might be getting this error?
Error: Invalid argument passed to UnMountTool()
Maybe the type of variable being used is expecting text or an int value and its telling you the "value" being used is incorrect.
UnMountTool is usually used for the toolchange sequence
