I normally use UG to generate code. But I also need to write G-Code manually. I almost always manage to make typos with zeroes and O's, i.e. "GO" instead of "G0". This causes me considerable angst, especially when my typo is in a sub-routine, since Vericut stops scanning the sub-routine as soon as it finds my error. Both times this has happened I went into a tailspin for a day or so until the error was seen.
My suggestion is either:
a) Provide an option to put a dot in the middle of a Zero
or
b) Allow the user to specify a different font in the listing window. For example, the "Arial monospaced for SAP" available on our network does put a dot in the middle of a Zero.
You know, in the old days, before Microsoft, computer terminals always put a dot in the middle of a Zero. How about it?
Hello Robert,
What you really need is a quick way to find this 0/O mistake (option C?).
In the control file, you add a message macro that will output a warning each time you use a O in the code. So you can see it in the logger at the bottom of the screen of in the log file.
Option C, it is!
Thank You Very Much!
