#1 2018-10-26 12:40:49
MKoňařík
Axis priority
Hello all,
Can anyone help me to set rotary axis priority?
I have angle-head  with B-> A kinematic.
I need to control priority axis by Plane spatial.
Priority should be to + values first A second B and to - values or setting back to zero B axis and then A
I set the priority in the tab Axis priority in Machine Configuration, but it still not work.
Thanks for any help
#2 2018-11-23 18:36:56
igor
Re: Axis priority
I have made some tests with syncronos movement using axis priority, but was in some years ago. As I remeber, you need to set wich group of priority vericut should use, with the macro:
AxisPriorityGroup
And then, the vericut will do the movement using the feed rate written in "Rapid Rate" field.
This only makes sense if you have more than 1 group of priority, as I had.
Igor Freitas
CNC programming
GROB - Brazil
