#1 2018-05-24 08:15:14
igor
Manipulate driven points with macros
Hello everyone!
I've been trying to manipulate the driven point of a polisher tool (when it is in spindle) by macros called with D1.
The reason I want to do that, is because I need to simulate the brushes always in the original preset, and 15 mm lessen preset (this offset is settable with a variable called SHIFT_MAX).
I tried to macros:
ZTool_Offset_Comp_Name
NumLengthCompZ
But it didn't work fine...
Do someone knows how can I get it?
I just don't want to create 2 indetical tools with this difference or change the program....
Igor Freitas
CNC programming
GROB - Brazil
#2 2018-05-30 07:52:38
Lesley M
Re: Manipulate driven points with macros
Hi Igor,
I once hade to influence the driven point of a probe.
I used the following macro's:
"ToolLengthCompValueDirect" ==> use to define the difference you want to apply to the current driven point
"ToolLengthCompPos" ==> use to define the direction (longer / shorter)
As an alternative you could define 2 driven points for the tool (in toolman) and switch between the driven points by macros "GageOffsetDrivenPoint" and "ToolCutterComp".
Hope this helps.
Kind regards,
Lesley
Lesley Morsink
ASCO Industries
TDM 2017 - CATIA V5 - ICAM CAM-POST- MACHpro - VERICUT 8.0.4
