I'm trying to configure Vericut to read an "IF" statement, and perform the jump to the line after the Tool Change.
Here is the NC code:
IF[VATOL EQ 239]NSKIP
M6T239
NSKIP
I've got 'VATOL' created as a variable. In the code above, say I load T239 in the spindle with MDI. If I then run that NC code, I need to check the expression [VATOL EQ 239], and if it is True, then I need to jump to the next occurrence of 'NSKIP'.
How should I go about configuring this to work in my Okuma CTL file?
I'm going to send the question to CGTech support, but I thought I'd also ask here too...
Colin
I believe this is related to sequence labels, I am trying to work through the same thing right now. Did you get an answer from support?
