#1 2005-08-17 07:52:57
Packer
How to creat a control file (ctl) for vericut
I am a new user of Vericut.
here we have some machines with OSAI 8600 CNC, and we'd like to simulate the machining on Vericut. how could I get that file? and how to creat it?
#2 2005-08-18 00:41:58
chaddy Summy
Re: How to creat a control file (ctl) for vericut
Hi Packer.
Can you tell me more about the machine the control is for? I used to run AB8600 (a really old one). Also will you be using E parameters?
The more data you supply the better
#3 2005-08-18 01:02:58
Packer
That is for Starrag NX155, it's a 5-axis blade milling machine. I think it is also an old machine. :-)
#4 2005-08-18 17:04:09
you should start with a control that is similar to your control. VERICUT comes with several controls in the Library folder.
I would recommend to start with an Allan-Bradley control:
Setup > Control > Open
Shortcut= CGTECH_LIBRARY (top right corner)
select : ab_8200.ctl
This control should cover most of the main G and M codes in your program.
