#1 2015-08-20 22:00:21
epoirier
MachineTravelLimits variable
Can someone provide an example on how to use the MachineTravelLimits variable in a macro? Thanks.
#2 2015-09-03 19:21:09
igor
Re: MachineTravelLimits variable
I have some difficults with this to..
I guess you can't setup the values, only thing you can do is create many travel limits (Group 1, Group 2, Group 3) and by these macros (below) manipulate wich of them do you want turn on:
TravelLimitErrorReporting
TravelLimitGroup
Igor Freitas
CNC programming
GROB - Brazil
#3 2015-09-03 21:21:39
Verifun
TravelLimitGroup
Igor is spot on:
This is how it works - In this example we are limiting the Y axis travel of a MillTurn when a facing head is mounted.
Here we load travel group "1" - Reduced Y axis travel
Nothing
Here we load travel group "0" - Regular Y axis travel
Nothing
And this is how we define travel groups that are called by the macro "TravelLimitGroup"
Nothing
Hope it helps...
#4 2015-09-28 19:08:14
epoirier
This was not exactly what I was asking about, but there are a couple places where I can use this information so it will be very helpful. Thank you. As for my original question, I figured out how to use the variable.
