I am using wear and control compensation on the same part. When I vericut the wear is showing gouge.
What does the code look like. You may need to make it not process the wear comp in order to cut straight.
Not sure if I'm saying something wrong here but I think you can't have both ways in the same program..
Well, one way to have this in the same program is altering the tool radius via program...
Changing to wear in a tool defined to work with control in Heidenhain:
TOOL CALL xxxx DR-y.yyy where y.yyy is the real radius of the tool with a negative signal...
All modern controls (2000-Present) will allow you to do this..
