When we were considering the purchase of Vericut, we were also looking at NCSpeed.
One function that NCSpeed had, that I would like to see in Vericut, is the ability to display a wireframe of what the original cutter path would look like. Coupled with this ability was the ability to display a wireframe of the optimized nc file.
Both wireframes also had segments within the wireframe that you could click on and see the feedrate for that particular segment. The optimized wireframe had colors that represented areas of increased or decreased feedrates. This just made it real easy to get a visual so that you can see if you are getting results that you would expect to see.
