#1 2013-04-04 13:40:37
igor
Max tool length
Hey guys,
I'm really exausting with this question, I need to check the maximun tool length before change the tool, to be safe of crashes with magazine,
but I'm still looking for a macro that get this value of the tool man, but I'm can't find one that could be useful...
Look, the maximun length don't means the same of one gage...I can have a tool with 3 diferent gages but, anyone are the maximun length...
Anyone could give me a light about this question???
Igor Freitas
CNC programming
GROB - Brazil
#2 2013-04-04 22:11:16
Verifun
Re: Max tool length
Igor,
This might work:
CurGageOffset
So you could set something like this:
<Macro Name="SetDynamicVars" Scan="no" AfterMotion="no">
          <Override  Type="text"  Value="CurGageOffset  $TC_DP5 $TC_DP4 $TC_DP3"/>
        </Macro>
This way you would store the X Y Z offsets from ToolMan in the variables  $TC_DP5 $TC_DP4 $TC_DP3 respectively, which would be also updated dynamically thanks to the macro "SetDynamicVars"
Take a look at the sin840d.ctl control in the default library. Search for CurGageOffset or SetDynamicVars macros or $TC_DP3 and you should see something in this direction...
Then you could check the value of $TC_DP3, and if it is greater than x you can do something about it...
I think you already figured it out at this point...  :wink:
Daniel
#3 2013-04-05 12:38:55
MustaphaC
Re: Max tool length
Good point Daniel,
Here is another way oriented more like a Tool Magazine "PLC" parameter, no need to create any extra check in the control. If you create a Tool Chain magazine then you can fill in the maximum Tool Lenght the pockect can load
See ...\samples\tool_changer_carousel_haas.vcproject, open Project Tree and Configure Panel, select "Tool Chain" component, tab "Tool Chain"
[attachment=0:3hbpbnd3]<!-- ia0 -->ToolChain.png<!-- ia0 -->[/attachment:3hbpbnd3]
#4 2013-04-05 12:41:49
igor
Re: Max tool length
Thanks Daniel,
But I need to get the Tool lenght, in fact that, some tools, the lenght are diferent of the gage, like this:
http://www.uploaddeimagens.com.br/image … ot039-tif/
The Gage 1 and Gage 2, I can control by the macro SetDynamicsVar - CurGageOffset, but the maximun length is in the last cutter...How can I control this???
I don't know any function or macro in vericut, that gives me the value...
I need this to control the moves, to avoid a colision. (T-change program use these values to prevent a accident, bringing the Z-axis back if necessary)
In machine, we have the magazine field - MAX TOOL LENGHT - and we have the values of tool check, but In Vericut I don't know...Do we have something that help in this case and get the values???
Igor Freitas
CNC programming
GROB - Brazil
#5 2013-04-05 12:48:34
Verifun
Re: Max tool length
Mustapha,
That's a really good point. Thanks for sharing that!  :wink:
#6 2013-04-05 12:54:14
igor
Re: Max tool length
Mustapha,
Doing this Vericut just will give an error when the tool lenght is greater then what I put???
Cause, in fact, this problem occurs becuase my machine has 2 magazines, one behind another, and I need this information to make a verification in tool change program (as the machine does):
IF $MAX_TOOL_LENGTH_VERICUT > MAX_TOOL_LENGTH
Z=IC(MAX_TOOL_LENGTH-$MAX_TOOL_LENGTH_VERICUT)
ENDIF
being:
$MAX_TOOL_LENGTH_VERICUT -> Vericut variable (macro) that gives me the length of the active tool
MAX_TOOL_LENGTH -> A user varible, that take the value of the max.tool.length for the first magazine....I set this, like - 200mm
Igor Freitas
CNC programming
GROB - Brazil
#7 2013-04-05 13:36:52
MustaphaC
Re: Max tool length
Yes the magazine will look for one value only. In your case you might need to use the SetDynamicVars as suggested by Daniel and create a driven point at the end of the tool to get the maximum tool lenght, store it in D99 for example, then use D1-D2 for Gage 1 and Gage 2.
The SetDynanicVar as it is named will dynamically get the current offset, if D99, you will get the maximym lenght as you want, if D1 you will get the Gage 1 etc...
Hope that helps
#8 2013-06-18 12:05:12
GregM
Re: Max tool length
Surely you've already resolved this but I thought I'd throw a solution in that is a little unconventional.  You could create a small cylindrical line in the path of the tool change and have your collision detection determine if the tool is long enough to reach the feature.  If the tool is too long you should get a collision warning.
#9 2013-06-28 18:08:02
Re: Max tool length
Our machines simulate the tool going through the tool change door in the gripper.   I just make the edge of the sheet metal or door opening be the same as the max length of a tool in the gripper.  Then have collision checking on between the tool and the sheet metal tool change door.  If the tool is too long, it generates an error during tool change as long as collision checking isn't turned off.
