#1 2012-12-13 20:39:44
cylinder
How to tell Vericut Jaws are Spinning?
We added a 'Z' axis Collision Detection in the Machine Setup and that works fine
for Drilling and Milling. How do you tell Vericut the Jaws are spinning in Turning Mode.
#2 2012-12-14 00:43:35
Verifun
Re: How to tell Vericut Jaws are Spinning?
Not sure if I got your question, but I think as long as the jaws are mounted in a chuck (And usually a chuck is mounted in a spindle component) Vericut will spin them while the turning spindle is active...
#3 2012-12-18 09:23:36
Be sure you have a Machine/Cut Stock view active. spindle rotation aren't shown in a Machine view.
#4 2012-12-19 18:56:30
cylinder
Vericut should error though correct?
#5 2012-12-20 09:21:26
No matter if you have or don't have a machine cut stock view visible, Vericut will detect the error if you hit a spinning jaw.
#6 2013-01-28 15:27:08
GregM
I put a small round circle modeled at the OD of the chuck that is a different color than the chuck.  When the chuck is stopped I see the circle and when the chuck is spinning I see a band of color going around the chuck OD.
