Got this question from a colleague:
"Is it possible to set up Vericut to generate an error message if wear comp is activated on an arc move or if it is activated with no lead-in? About once a week I get the cutter comp alarm at the machine when I leave the comp set to 'wear' with lead-in lead-out turned off. It would be great to catch these at the computer."
Is it?
Daniel
The arc one should be possible. You can add a condition on the activation code to check to see if the circle code is present. If it is give an error. I took a different approach and checked for these conditions in the post processor. We use NX and it was quite easy to check for these conditions.
