Does anyone know the syntax format for "ChangeWorkCoord" macro?
G15 H03 ......... (H03 = 10 12.675 1)
This is the code from the program. Ex:: VC6 = 12.675
CALL O1503
VZOFY[3]=VC6-5.750
CALL O1503
I have VZOFY define as array variable
When it read to the line VZOFY[3]=VC6-5.750.
VZOFY[3] variable = to 6.925
Then it will shift workcoord to 10 6.925 1
Word Format:::
VZOFY Special Vairable Name
VZOFX Special Variable Name
Variable:::
VZOFY[25]
VZOFX[25]
What do I need to do for it to regconize the VZOFY variable, work index no. [3] and in the same time shift Y-axis down by 5.750.
There are::
-- WorkCoordIndex
-- WorkCoordXValue
-- WorkCoordYValue
-- ChangeWorkCoord
But which to use and how to use is the problem...
It would be better if there is example of syntax for every macro in the help file.
I got everything straighten up...
Hello,
I am looking to do something similar with a variable array and pass it to work offset locations. Would you mind passing along the details?
Eric
