Could somebody please guide me how to fix this problem??
I am using ver. 7.xx
Thank you in advance.
Hello,
any one??
please
Which control are you using?
VARIAXIS M730
A possible reason could be the units interpretation of the feedrate, MM/MIN vs. MM/REV for example. If using MM/REV then spindle speed needs to be correct etc...
If you use the G-Code debug and check the cycle time you can see each single motion with the corresponding time. For example:
- Open the sample project file "fanuc_subroutines_multiple_parts.vcproject" in the samples folder
- Configure project to stop at line #40
- Create a G-Code log file by Project > G-Code > Process Options, use Browse to select folder and file name, for example "Debug.log", in Debug tab use "Debug Macro" + "Cycle Values" + "Debug Timing", OK
- Press play
- Step by step until G#3G99Z-#26R.1F#9Q.1 (at that point #3=83
- Now open the G-Code log file by Project > G-Code > Process Options, "View G-Code Log File"
- At the end you get the information about the last NC block, something like this:
Debug: MACRO:BlockInit, WORD:, TEXTSTR=, VALUE=0
Debug: MACRO:CyclesDeep, WORD:G, TEXTSTR=#3, VALUE=83 CONDITIONAL: * *
Debug: MACRO:SetCycleRetractLevel, WORD:G, TEXTSTR=2, VALUE=0 CONDITIONAL: * *
Debug: MACRO:SetCycleDepth, WORD:Z, TEXTSTR=0, VALUE=-0.45 CONDITIONAL: (CYCLE ON) and (ABS_INC ABSOLUTE) and (MOTION_PLANE XY)
Debug: MACRO:SetMotionFlag, WORD:Z, TEXTSTR=-#26, VALUE=-0.45 CONDITIONAL: (CYCLE ON) and (ABS_INC ABSOLUTE) and (MOTION_PLANE XY)
Debug: MACRO:SetCycleRapidLevel, WORD:R, TEXTSTR=0, VALUE=0.1 CONDITIONAL: (CYCLE ON) and (ABS_INC ABSOLUTE)
Debug: MACRO:FeedRate, WORD:F, TEXTSTR=#9, VALUE=10 CONDITIONAL: * *
FEDRAT/10,IPM 200
Debug: MACRO:CycleStepValue, WORD:Q, TEXTSTR=.1, VALUE=0.1 CONDITIONAL: (G 73 83)
CYCLE/DEEP, RAPTO, 0.1, FEDTO, -0.45, STEP, 0.1, CLEARANCE 200
Debug: Drill Cycle Arguments
Debug: motion_plane = XY Plane
Debug: initial_point = (0.5, 0.866, 0.5)
Debug: Rapid Level = 0.1, type = Absolute
Debug: Part Surface = -0.1, type = Incremental From Rapid Level
Debug: Depth = -0.45, type = Absolute
Debug: Retract Level = 0, type = Incremental From Rapid Level
Debug: step_down = 0.1
Debug: step_up = 0
Debug: Drill Cycle Apt Parameters
Debug: GotoPoint = (0.5, 0.866, 0)
Debug: Tool Vector = (0, 0, 1)
Debug: RapidTo = 0.1
Debug: FeedTo = -0.45
Debug: RetractTo = 0.1
Debug: StepDown = 0.1
Debug: StepUp= 0
Debug: Time Attributes: Drill cycle: RAPTO
Debug: Delta time = 0.002
Debug: Time Attributes: Drill cycle: Step RAPTO
Debug: Time Attributes: Drill cycle: Step down
Debug: Delta time = 0.01
Debug: Time Attributes: Drill cycle: Step up
Debug: Delta time = 0.0005
Debug: Delta time = 0.02
Debug: Delta time = 0.001
Debug: Delta time = 0.0015
Debug: Delta time = 0.0025
Debug: Delta time = 0.015
Debug: Time Attributes: Drill cycle: Dwell
Debug: Delta time = 0.0028
Debug: Time Attributes: Drill cycle: RETRACTO
Debug: MACRO:BlockFinish, WORD:, TEXTSTR=, VALUE=0
Debug: Total time = 3.5195
As you can see, you have the Feedrate used (FEDRAT/10,IPM) and the time corresponding to each Step up, Step Down, RAPTO (Rapid Motion to) etc...
See if you have a Delta Time somewhere which is not expected then try to find the cause.
I hope that will help you to get a more accurate G83 cycle time
Thanks for the reply.
Well, it seems over my head :? . But i will try it when a have alittle more time.
Happy friday.
...or you can simply send your files to Technical Support, they can quickly look at it for you.
