#1 2010-06-29 16:10:22
Tinhman
Mazak_nexus_510c Machine simulation
Good morning guys,
I got this error:
******************** TOOLPATH ERROR REPORT ********************
Error for line 42, Filename: 98171.EIA
M06
Error: Invalid Spindle Component Name Tool_Spindle
M06
Error: Invalid Spindle Component Name Part_Spindle
Error for line 45, Filename: 98171.EIA
G00 G17 G90 G54 X6.6912 Y6.6626 S600 M03
When i tried to run the machine simulation with Mazak_nexus_510c and i am using version 7.0.3
Could somebody please show me how to fix this??
Thanks in advance
Tinhman
#2 2010-06-30 05:41:50
VERICUT_USER
Re: Mazak_nexus_510c Machine simulation
I think that without the FileSummary to help in this matter will be difficult.
Gentleman will walk but never run.
http://www.postprocessor.ru
#3 2010-06-30 17:59:17
I got that error once, and it was because I renamed the spindle component, and I had macro's in the control file that call the spindle component, by name.
Look at your word / address, on S, M3, M5, M13, ETC, can see if you have one of those macro's call the spindle component, by name, and make sure the name is correct.
jm6c
Daverf
#4 2010-06-30 20:29:34
It looks like you have the wrong control, a call for the part_spindle indicates that the command tries to spin the part and tries to do a turning operation.
In the Library folder, select the control called mazak_nexus510c_matrix.ctl and it should process correctly.
#5 2010-07-01 02:45:23
Tinhman
Thanks. It fixed my problem but i have another question. All my machines have a sub plate about 2.5" thick ontop of machine table and my question is:
is there any way i can change the machine config.or setting up the vericut? so when i create a stock, my stock alway sit on top of sub plate not on top the mahine table?
Thanks in advance
#6 2010-07-01 16:00:54
Display your Project tree
Select the Attach component branch in the tree
In the Configure Component panel in the bottom of the Project tree, Translate tab
Position = 0 0 2.5
By moving this component, the stock and fixture will be translated 2.5 inch
Configuration > Machine Save as...
Save the machine somewhere on your network. Save the Project file as your starting template.
#7 2010-07-01 17:34:10
Tinhman
Thanks a lot
