I was wondering how I can sent machine home in vericut Before toolchange, If the nc program did not have G91 G28 Z0.
Dnguyen
You could set your tool change to include commands to send the machine home. On my Okuma MX-55 for example:
In Word Address:
Miscellaneous
>M6
>ToolChange
>XAxisMachineRefMotion
>Value=-20.5
>YAxisMachineRefMotion
>Value=0
>ZAxisMachineRefMotion
>Value=23.5
All you have to do is change the values to make your machine go to the right location.
A better and simpler solution is to use a Machine Reference Table, this is a location the machine will retract to with a G28. If your machine was built with Z0 defined in a retracted position, you probably do not need it, but if your Z0 is on top of the table or in a collision position, then you need a table to tell VERICUT where to go.
Configuration > Machine Settings...
Locations tab
select the Machine Locations branch
Location Name = Machine Reference Location
Add
type the values where you want VERICUT to retract
Values (XYZABCUVWABC) = 0 0 25 (for example)
OK
you will need to save your machine file to preserve this change
You can also do the same thing for a Tool Change Location table
thank you for your help ![]()
