Hello Everybody,
I have created a 5-axis milling machine on vericut in order to simulate a 6-axis turning process (turning tool is located in the spindle, which revolves around Z axis, therefore there is a third rotary axis defined: C which revolves around Z axis)
As it is a 6-axis process, spindle rotation is not switched on, it is used as the C axis.
During the simulation , I get an huge amount of the following error messages: "Collision between the cutting zone of the tool ### and the machined part with the spindle turned off at line ####... (translation from the french).
Those errors slow down incredibly the simulation.
Is it possible to disable this "spindle on" check with turning tools on milling machine ?
n.b.: I don't care about material removal (it is actually no more than 0.4mm). I just want to check whether the tool holder collides with the stock or not.
Thank you in advance for your help
Best Regards
Luis
Vericut version: 7.0
The best way to configure this, would be to turn on the spindle with a C command, resulting on the same results on the part.
Configuration > Word/Address...
under Registers, select C *
Select the condition * *, with CAxisMotion
right-click, Add/Modify
Macro name = ActiveSpindleActiveTool
Add (leave the panel open to add more macros)
Macro name = ActiveSpindleOnOff
Override Value = 1
Add (leave the panel open to add one more macros)
Override Value = 0
check the box "Process After Motion"
Add
Close
This will turn on the spindle with a Caxis motion but will turn it off inmmediatly after the C axis command. This will avoid the error without affecting your simulation
Thank your for your help, SergeV, but it doesn't work very well.
You are right, I get no more error messages. Nevertheless, simulation is even slower than before. Because for every C move, vericut spins the active turning tool around Z axis, thus creating a revolved body. At the end of every C moves, turning tool returns to its normal shape. These constant transformations slow down simulation in a worse way than before.
Is it possible to disable this tool shape update ? That would solve my problem. I have searched for such a macro but haven't found it so far.
Luis
You could turn on the spindle with C axis but only turn it off with the next tool change. So, when this special turning tool is loaded, it will stay in a revolved state until the next tool is loaded.
Since you always have the spindle off during a tool change (I hope), you could add the spindle off macros to your tool change macros. If the Spindle is already off, it won't affect anything.
Just ideas...
