#1 2009-11-16 14:31:53
prayasam
Guest
Cycle Time v7.0
Hello,
In Version 7, I created a simple program that makes a move using G01 F100 X100.
The vericut log shows the total cycle time of 4 min.  (instead of 1min or slightly more.)
Is there any other option that needs to be turned on/off to get accurate prediction of times?
P.S.: Admin: Sorry if the same topic is posted elsewhere. I appreciate if you can kindly move this post to the right place.
Prasad
#2 2009-11-16 18:38:25
Re: Cycle Time v7.0
In you test, make sure that your initial position is X0. and that you are moving 100 inch or mm.
Are you in G01 mode?
to test, I opened vericut.vcproject
MDI: X0.
Info > Status
-- time is .1275
MDI: G01X100F100.
-- time is 1.1275  a difference of 1 minute as expected.
#3 2009-11-17 15:29:26
prayasam
Guest
Re: Cycle Time v7.0
That makes sense.
I had setting defined for inital machine location. I was under the impression that the machine X is at 0 at the very beginning. But in vericut point of view, it is at X500. Hence the time differences.
Thanks a lot.
Prasad
