#1 2009-02-13 08:30:56
calpay2009
Making Vericut Give error on specific states
Hello guys,
                I tried to configure such a thing.
                In this machine i'm working    M53 means that the head is horizontal (B=90 degrees)
                                                               M54 means it is vertical                         (B=0 degrees)
                                                               M55 means none of the below               (B is between these angles)
                I want to see that if i put M54 to the g-code and B is let’s say 20 degrees i should have an error.
                That’ll be the case on all others, if there is M53 and B is 40, or There is M55 and B is 90, etc…
I need help on this matter.
Thank you guys,
Cem ALPAY
CGtech Reseller
Istanbul/TURKEY
#2 2009-02-16 06:52:30
Svante
Re: Making Vericut Give error on specific states
I have answered a similar question in this thread.
<!-- l --><a class="postlink-local" href="http://cgtech.com/forum/viewtopic.php?f=2&t=1061">viewtopic.php?f=2&t=1061</a><!-- l -->
If you have more questions just ask.
Best regards,
Svante
Svante Eriksson
System owner
#3 2009-02-16 14:07:07
calpay2009
I'm having problems because his is a three way thing.
Could you explain it a litte more, please?
Cem
#4 2009-02-20 12:13:22
Svante
I'm not sure I understand the whole problem. I guess this is an Heidenhain control so please see example
An example: Variable for tracking the actual B-axis position is for example Q111
Then put conditions as per:
M54 with condition Q111 NE 0 gives an error
M53 with condition Q111 NE 90 gives an error
M55 with condition Q111 EQ 0 or Q111 EQ 90 gives an error
Svante Eriksson
System owner
