HI.
We are looking at Verict to debug our programs for our Horizontal lines. We would use Vericut to not only find bad toolpaths but to help visualize cutter load and problems that Vericut may not show. I have found it difficult to follow cuts at times because a tool will change all of its cuts into the same color.
Suggestion #1 the work stays one color say green and the tool removing material will change color on surfaces being cut to say blue till there is a z change. Then the blue will revert back to green thus all material being removed will become visible , even for small .005 clean up cuts.
Suggestion #2 We normal have multiple loads at different locations on any given pallet.
How about attaching a camera to the spindle that would follow the spindle and tool as it
Moves from part location to part location. Or a window that will automatically switch as different
work offsets are called
Thanks Alex C
